Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
The operating system for iPhones and iPads.
13 Fragen Alle anzeigen
How do I fix frequent video buffeting and frozen images?
I watch Netflix and the video frequently buffers or the image freezes or becomes fuzzy
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
iPhone LCD Display Fix Kits
Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
Kits kaufen
Reduziere die Reparaturkosten, nicht die Qualität.
Kits kaufen
1 Antwort
Gewählte Lösung
Your network connection is not able to sustain the stream rate and/or is dropping on you.
Check your WiFi AP are you close enough to it? Also check to see if others are also running WiFi AP's near you you maybe fighting for the same bands. Look at changing your band if you can.
If your connected over your cell service then the location of the nearest tower and the number of others connected to it can cause this as well. Talk with your cell provider for help. You may not be able to get anything better.
Check your wired network are others in your household fighting for bandwidth? Your network provider (cable or other) may not have provisioned the line correctly (very common) and/or your exceeding what you were provisioned. You may find a given time during the day is worse than another if so your provisioned allotment is not being met.
Lastly, things happen! the connection thru the Internet to Netflix's servers may not be able to sustain all of the people connected at the given time.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Kimberly wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 191
