Zum Hauptinhalt wechseln
Smaller, thinner, quieter model of the Playstation 2 (SCPH-7XXXX) released by Sony in September, 2004.
68 Fragen Alle anzeigen
PS2 slimline no power.
Accidentally inserted wrong power adapter into PS2 Slimline, now I have no power. Is there a fuse or some other component that I have to or can replace inside to get it working again?
Ist dies eine gute Frage?
Bewertung 3
Kommentare:
Most likely happened is that it powered on and soon after a capacitor or circuit got fried.
if this is true was there any smoke or the smell of something burnt?
von
Hi oldturkey there was no smoke or smell, the device just simply failed to start. For this reason is why I thought that there might be a protective fuse.
von
Einen Kommentar hinzufügen
1 Antwort
John, attached image will show you all the fuses on your logic board. Use a multimeter to check for continuity of those fuses. Pay particular interest to the resettable fuses. Of course, look for any charred, burned, or missing component as well. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
Cheers for the diagram oldturkey and thanks for the help
von
you are welcome, good luck.
von
Stupid question, how do you reset the fuses??
von
Antwort hinzufügen
John wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 10
Letzten 30 Tage: 44
Insgesamt: 7,796
