Zum Hauptinhalt wechseln
Die Nintendo Wii Spielekonsole erschien Ende 2006 und wurde bis 2011 produziert.
286 Fragen Alle anzeigen
USB for external storage is broken
I bought the WII unit 4 years ago. My WII has two USB port. One for Keyboard and one for the external hard drive. The USB for external hard drive is broken. I need replaced. Can you fix it and how much would it cost if it can be replaced.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
mike, ifixit does not do any repairs. Here you will find advise on how to fix things yourself :) The USB port is soldered to the board. You could try and replace it by purchasing a USB port from places like Mouser.com or digikey.com. the other thing you could do, is to solder a USB cable to it. Get yourself a USB cable, cut the male end off, and solder those to the board, this will leave you with a female port to connect your HDD to. Either or, you will have to disassemble your WII and do some soldering. Follow these guides.Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
mike wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 4,834
