Zum Hauptinhalt wechseln
Model A1138 / 1440x960 screen resolution
84 Fragen Alle anzeigen
Why is my power adapter fuse blowing?
Hi
I have a PowerBook G4 15" 1.67Ghz model A1138. The power adapter keeps blowing it's fuse every time I plug it in. When I plug it in to the computer, there are no lights on the charger ring, probably because the fuse has blown again. I replaced the plug fuse and removed the DC board connector from the logic board inside the computer, and the charger ring glows orange. I tested the voltage and it reads 24.7 volts. When I plugged the DC board connector back into the logic board, the fuse blew again.
I suspect there is a short circuit in the logic board, can anyone confirm that this might be the case? If it is, would I need to replace the entire logic board or is there any way of finding and fixing the short circuit?
Thanks :o)
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
This is usually a power board problem caused by the Intercil IC or another component on the board. Find out which board you have and find the schematics, since you will need to do component level repair if you do not want to replace the motherboard.
Blind replacement of the DC-In board generally doesn't help. Sometimes it works, but the majority of the time you have other issues on the motherboard that need to be repaired along with repairing or replacing the DC-in board.
War diese Antwort hilfreich?
Bewertung 1
try a new power adapter.
Bewertung 0
1 Kommentar:
Thanks, but I have already tried 2 different power adapters with the same result. Both adapters work fine on each of my 2 other laptops, being another PowerBook G4 and an iBook G4. There's definitely something not right inside the computer, else the DC board would not be working fine when disconnected from the logic board. Hope that makes sense? ;o)
von
Antwort hinzufügen
Adam wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 6,220
