Zum Hauptinhalt wechseln
Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
113 Fragen Alle anzeigen
Frage geschlossen
Doesn't boot, blue screen with patterns
After chime, apple logo and activity circle and it freezes in this state. or sometimes (maybe by pressed D button by startup) it changes the screen twice - clear blue to blue with small green patterns, with mouse in the left upper corner. I can move the mouse cursor but nothing more appears on the screen. sometimes the activity circle replace the cursor and I hear the HD working. I would like to fix the problem, any clues? Thanks
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
I have a new situation. I can now startup in Safe mode, but if I try to startup in standard modus, it freezes as described before. I have also run the apple hardware test with no problem result.
von
Einen Kommentar hinzufügen
2 Antworten
Did you accidentally set the disk permission to No Access?
If the disk in question is your Mac OS X startup disk and your computer stops starting up at the blue screen, restart with the Command and S keys held down, and enter the following commands:
mount -uw /
chown root /
chmod 1775 /
exit
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Yes it is the startup disk. I have done this, than I got some more text rows and than it stopped. Last row: Oct 5 ....... iMac24-3 /usr/sbin/ocspd[70]: starting
von
Hey
not sure if you resolved this issue but from experience i have seen quite a few 24" iMacs where the graphics card is causing the unit to freeze
Most commonly the spinning gear under the Apple logo stops spinning and freezes - replacement video card from Apple has fixed the issue
Also worth noting that Apple only Have the higher spec video card available as a spare part - the failing one is no longer purchasable :/
Martin
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 1,026
