Zum Hauptinhalt wechseln
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
173 Fragen Alle anzeigen
Device will only stay on with power connected
Hi guys,
So I have 2 iPod nano's here, 1 is a 16GB and one is an 8GB. The 16GB has a trashed screen and wont hold its charge, Whereas the 8GB has a trashed screen and does hold a charge, (Screen still comes on and can just about operate it, the 16GB just has a white screen)
I have dismantled both a couple of times and was just wondering if I soldered the battery of the 8GB onto the 16GB and replaced the screen would it work? the 16GB battery looks slightly different as its older, will this make any difference as well?
Thanks
Rob
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Rob Berry, the different look could be caused by different manufacturers as well as different model age. Check the physical dimension, they will have to be the same (I am certain they are) Yes, it should work, but you are still replacing a used battery. I would suggest a new battery. That way you wont have to replace it again later on. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 0
Check the circuit board lines running from the battery for any signs of charring, it may shorted out on a lead running from the battery. As well as reseating the connection points on any other components.
Bewertung 0
Antwort hinzufügen
Rob Berry wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 565
