Zum Hauptinhalt wechseln
MacBook Pro Modelle mit 13 Zoll-Displays
6737 Fragen Alle anzeigen
won't turn on and does a beeping soung instead
Hi there, I had some problem with my macbook pro a while back, in which the screen was getting blank/frozen and I had to force quit it, and when i tried to turn it back on, it started beeping and would not turn on...then I would wait some hours and it would finally turn on. It was acting like this for a while and I managed to fix it by repairing the disk in disk utility and it was working fine...
Now, since yesterday, it started again, and i had to force quit it, but this time, it is not turning on at all anymore, and it only does the beeping sound when I try to turn it on...firts it does one beeping at a time, and then I force quit it again and turn it on again and it does a faster beeping sequence.
Can anyone help me?
my mac info is:
Mac OS X
version 10.6.8
2.4 GHz Intel Core 2 Duo
4 GB 1067 Mhz DDR3
I never did any work on it, never changed anything...it is just like I got it from the shop.
Thanks
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Punktzahl 5
Kommentare:
Can you supply the last four digits of your serial number so we can ID your system.
von
Einen Kommentar hinzufügen
iPhone Akku Fix Kits
Nur $29.99
Buy Now
Nur $29.99
Buy Now
4 Antworten
Gewählte Lösung
3 successive tones, a 5-second pause, 3 successive tones is the RAM integrity error. As Bernd recommended reseat your memory or replace it.
Heres the Apple TN on boot up tones Tone Errors for reference
War diese Antwort hilfreich?
Punktzahl 3
Hi Tania,
how many beeps do you hear? Or is it beeping constantly without an interruption? Sometimes this symptom is caused by the memory. Have a look if it is seated propperly.
Good luck
Punktzahl 0
Kommentare:
The power on self test error codes either beep or blink the sleep lite in repeating patterns. LCD freezes and beeping comes out of computer to go to a thread that explains what the different ones mean.
von
Start up and hold down the on/off button until led will blink rapidly and mac will start up fine.
Punktzahl 0
Kommentare:
i am getting repeated 2 beeps and mac wont start up. I have not changed hard disk or anything in my Mac book pro.
Please help
von
Ali - For future reference you posted a Question in the place where only Answers belong. Please use the add comment link to the appropriate Answer, Question or create your own original Question. FWIW 2 beeps mean in "old code" it meant incompatible RAM in "new code" it's no longer listed.
von
What the !&&* is this 100 points or can't vote no. The suggestion did NOT work.
Punktzahl 0
Kommentare:
Larry please explain what didn't work.
von
Antwort hinzufügen
Tania wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 6
Letzte 7 Tage: 22
Letzte 30 Tage: 84
Insgesamt: 65,820
