Zum Hauptinhalt wechseln
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
Laptop not turning On when pressing power Button
When I press on Power Button only the media player touch LED blinks once and the light for caps and numlock continuously blinks even I can see power on DVDROM and fan too moves . But none of the LED in front blinks and no power on monitor is there.
Could you please suggest me what should I do.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
can you attach an external monitor and see if you get anything? Any post beep's?
von
Use this : Dell AC Adapter LA90PM130
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Thanks for your Suggestion "oldturkey03"
I have troubleshooted it and found the reason, its because one of my RAM has gone Bad.
Regards,
Amit Lal
War diese Antwort hilfreich?
Bewertung 0
Some times the Heat sink & fan gets dust and due to which system gets heated.
Once cleaned can help overheating & abnormal switching off issue.
Bewertung 0
Antwort hinzufügen
Amit Lal wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 4,036
