the printer carrier for the black cartridge is burned out, thus it's not communicating with the black cartridge to make it squirt black ink. it can happen either way-color too.
printer carrier must be replaced.
my response to you all, screw inkjet printers because they're too much of a dang headache!!!!!
buy a laser printer, and you will be extremely happy you did! they're very competitively priced these days with inkjet printers, do not have even a fraction of the problems inkjets do because they use what's called a toner cartridge which last many months-i change my toner cartridges about once a year give or take.
yes, literally they're more expensive than inkjet cartridges, but compared to how long they last, you're actually spending less money than if you totaled up the number of times you had to buy inkjet cartridges just to equal the length of time laser toner cartridges last in comparison to inkjet cartridges.
plus, laser printers don't spend a minute or 2 making all that dang irritating noise preparing to print while you're wondering, "ok already, print, %#*!^@!"
i also buy my toner cartridges on ebay for around $100-$120 for all 4 colors!
i have this very good laser printer, the Samsung Xpress model #SL-C460FW i bought practially new on ebay for $130! excellent laser printer, plus it's my second laser printer in since 2003-my other one lasted that long!
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
5
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
30 Kommentare
Look at the settings in your printer properties.
von ABCellars
i did look at the printer properties, all is fine there. however; it still does not print.
von sdhowell001
Hi I am new to the forum, had the same trouble with my ESP 7250 would not print black and white, after trawling the net for solutions tryed every thing from printer solution to new print head still did not print black and white I uninstalled the the software reinstalled still nothing, tryed to download the latest software but said it was up to date I then started looking at the driver type and bingo there it was a generic Windows driver that was preventing the Kodak driver being installed I deleted it from print manager rebooted the pc run a word doc off with black and white print perfect, this was after three weeks off and on trying different solutions I believe that during one of many windows updates it had installed this generic driver hope this review helps someone with a similar problem looking at all the comments a lot of people are suffering the same problems
von Ernest Biggins
Could someone give me a walk though?
von mizfirebird
wow, same thing has happened to me too, i thought it was the ink, replaced both color and black and still only prints color. will try to install the kodak driver. do i need to un-install first?
von linchap
25 weitere Kommentare anzeigen
