Zum Hauptinhalt wechseln
Modell A1136 mit 30, 60, oder 80 GB Festplatte / Front aus schwarzem oder weißem Kunststoff.
797 Fragen Alle anzeigen
Replaced the hold switch and now click wheel is not working.
I have pulled apart my 30GB iPod video again to make sure I didn't miss anything. I have also done a restore with Itunes. The reset function works fine (holding the menu and center button until reboot). Toggling the hold switch on and off works fine as well. No response at all on any of the buttons other than the reset function. Please help!
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Retake it apart. Buttons may be stuck.
War diese Antwort hilfreich?
Bewertung 2
The click wheel has to align in a specific way...if im not mistaken 3 little holes on the bottom of the click wheel button should help you align with ribbon cable...do you hear click sounds when pressing the button?...if not then its not align properly
Bewertung 2
Check and recheck all ribbon cable connections, this is most likely where the problem is. Sometimes they appear all the way in but are not quite making contact.
Bewertung 1
When openning you broke your click wheel cable or you dont have it grounded because the tail ribbon of the clickwheel came of the frame of the iPod so know you iPod will not work
I hope this helps
Bewertung 0
Antwort hinzufügen
gary wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 12
Insgesamt: 6,555
