Zum Hauptinhalt wechseln
2,5 GHz Dual-Core Intel Core i5 Prozessor (Turbo Boost bis zu 3,1 GHz) mit 3 MB geteiltem L3 Cache.
264 Fragen Alle anzeigen
MacBook Pro 13 inch battery change?
is it possible to replace the battery?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
If your just wondering whats involved checkout the iFixIt teardown. MacBook Pro 13" Retina teardown
If you think your battery is having troubles you should bring the system to a Apple Store as its likely covered under warranty (less than a year)
War diese Antwort hilfreich?
Bewertung 1
It is possible however apple has made it so that you have to replace the top case in order to replace the battery as it is part of the top case. This is not going to be a customer installable-part. Your computer should still be under the first year of warranty, aka apple limited warranty, and if your battery is defective, they should replace it. Hope this helps!
Bewertung 0
tell me please iam change the top case mac book pro retina display i will also change the battery
Bewertung 0
1 Kommentar:
Please review the IFIXIT guide
von
Antwort hinzufügen
sven choi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 3,747
