Zum Hauptinhalt wechseln
Drahtloser Kontroller für die Xbox 360
90 Fragen Alle anzeigen
Central guide button has jammed
Right heres the problem, the guide button in my limited editionxbox 360 controller has jammed in place an now trys turning off the xbox every few minutes. I've not spilt anything on it, this is the only controller I've got thats suffered this problem, I've tried cleaning it with a mild alcohol cleaner which did nothing I also tried giving it a quick blast with compressed air which did nothing, is their anything I can do to fix this without soldering.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
James Roff, take a look at this guide. Clean all components with alcohol, all rubber and plastic components with mild detergent,. Take a look at the corresponding ends and see if you can find where it jams.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Cheers I'll give it a shot and get back to you on the results
von
Had to use a fine glass paper to smooth the guide button as it was rough and stocking but apart from that your advice was spot on =) cheers
von
Thank you for accepting my answer. Best of luck to you.
von
Antwort hinzufügen
James Roff wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 6,913
