Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2191 Fragen Alle anzeigen
water damage :( HELP
So i dropped my iphone in the pacific ocean.. normal right? anyways, i replaced the dock connector & battery but it's still giving me problems. It only works when connected to an AC outlet & works for 5 minutes before it reboots. In those 5 minutes I have no wifi, or att signal, no sound, no vibration. Everything works great besides that. paying 200 for the replacement is out of my budget. I can't seem to restore the phone either because several errors occur. I've already tried the rice method and now im just desperate and depressed for answers/suggestions.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
californiaxfresh, besides the "rice method" does not work. Rice does not do anything! I would most certainly suggest that you clean your logic board a bit further. Use this guide to clean your phone. It was written for a 3G but all the points still apply to your phone. The issue here is corrosion caused by the Pacific water. Rice will not clean the board at all. After you clean your phone, reassemble it and re-evaluate.
War diese Antwort hilfreich?
Bewertung 1
7 Kommentare:
thanks for replying old turkey! yeah i just took apart my whole phone and cleaned out the logic board. i found some sand in there. unfortunately while i was cleaning the board i also cleaned the white sticker so now its a little pink :(
von
Is a moisture indicator that would show Apple that this phone was exposed. This will not impede the function of the phone.
von
Yeah i understand. do u think i should keep going to the apple store in prayer that they might give me a free replacement?
von
You could try, worst case scenario will be a "No" :-)
von
if i tried cleaning my logic board and its still not working (i cleaned it with 70% rubbing alcohol ;) is it time to give up?
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
californiaxfresh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,041
