Zum Hauptinhalt wechseln
Kinect is a gaming peripheral for the Microsoft Xbox 360. It allows for audio and video input to let the player be the controller.
28 Fragen Alle anzeigen
They camara on my kinect isn't reading us to play
When we turn on the kinect to play the screen doesn't read us, and the screen has 2 white lines through where it shows the image of the person your suppose to stand in front of to have it read you, but it doesn't work is there away to fix it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
upgrade your firmware on xbox with all acessories disconnected, pull hdd away , than test it - and let us know ;)
good luck
War diese Antwort hilfreich?
Bewertung 1
Are you playing in a small room? There is a small environment setting in initial setup. run it again and listen or read closely.
Bewertung 1
Antwort hinzufügen
Barbara wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 528
