Zum Hauptinhalt wechseln
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
202 Fragen Alle anzeigen
What's the reason of this display trouble?
http://kmug.co.kr/board/data/hardware/er...
Hello. Please see the link.
17" IMAC's display had some trouble.
What's the reason? LCD or graphic card?
What parts need for repair?
Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This looks like a faulty graphics chip on the logic board. You have 3 options to repair this:
  • 1- Replace the entire logic board.
  • 3- What i have done that works best is to perform a BGA reballing on the graphics chip but you need specialized tools and skills with soldering to do this and can be more expensive than replacing the logic board
What I would do in your situation is attempt the reflow first to see if it works. If it doesn't then I would just replace the logic board. See this guide: iMac Intel 17" Logic Board Replacement
If you want more info on reflowing or reballing try a google search of GPU reflow diy, BGA rework.
I hope this helps, good luck!
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
That's a pretty insightful answer. This post is three years old, but the advice is still excellent.
von
Antwort hinzufügen
Taejoong wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 703
