Das Modell A1238 / 80, 120, oder 160 GB Festplatte / schwarzes oder silbernes Metallfrontteil
951 Fragen Alle anzeigen
Should I replace the logic board?
Hi everyone,
Thanks in advance for having a look at this. I have a 160GB classic 6th gen (I think).
It's had a good life but recently got a little wet, and the battery wouldn't hold charge. I could plug it in though - it would boot up from scratch but then work okay. I tried to dry it off for a couple of weeks - no cigar. I replaced the battery but had the same result. I have opened it up and cleaned some corrosion around the area where the battery cable connects to the logic board - in the process I removed the cover of the battery cable connector and saw that some of the pins had broken off. I re-assembled it all with the same result.
So - my question is, can I assume it is a logic board problem, and replace it? Or could it be something else, or a combination of things? I ask because the logic board is quite an expensive part - but still less than half the price of a new iPod! I would also buy a new metal back casing (I assume they work okay?) as mine is now quite out of shape with all my poking around.
My only other thought it that perhaps it is the dock connector? It always shows that it's charging the battery but it never really is. I assume this is a part of the logic board anyway.
Thanks so much - your wisdom is much appreciated.
Charla
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Punktzahl 0
Einen Kommentar hinzufügen
Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
Erfolgreich repariert? Genial!
Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
Wir sind alle Genies
1 Antwort
Gewählte Lösung
Charla, "cover of the battery cable connector and saw that some of the pins had broken off." This is a common result of corrosion damage. It sounds to me like you will need a new logic board or you can try and resolder a new battery connector. The battery connector is available on places like this, after you thoroughly clean the board. I would probably get a new board :-) Hope this helps, good luck
War diese Antwort hilfreich?
Punktzahl 0
Kommentare:
Thanks so much - that's what I'll do. I really appreciate your help!
von
Antwort hinzufügen
Charla wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 1,229
