Zum Hauptinhalt wechseln
Das Modell A1238 / 80, 120 oder 160 GB Festplatte / schwarzes oder silbernes Metallfrontteil
903 Fragen Alle anzeigen
New Battery, won't charge up
Hi ! I have recently bought a new battery for my iPod, because the last one was starting to have a short duration of use. But the problem is that the new battery won't charge up : the battery logo show that it's fully loaded after 1 minute, and the it drains after 1 minute too, and that's only when I plug the iPod to the sector, otherwise the sreen keeps flashing with le Apple logo. If I put back the older battery, everything works, but I don't wanna do this. Someone help ? Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
dustytill, if it works with the old battery, but not the new one, exchange the battery. It sounds like you have a gotten a bad battery. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 1
13 Kommentare:
Hi. Are you sure of this ? Cause I don't wanna buy another one if it doesn't work again...Thanks
von
You did say that the old battery works, but not the new one. To me that definitely means that it is your battery. Anything else is just a guess, you got to find a place to start....
von
I have to specify that my older battery was 580 mAh one, and the newer is a 850 mAh for a longer battery life. Does that make a difference ?
von
the mAh won't make a difference for as long as they are physically the same. Make sure they are the same thickness.
von
No they aren't the same thickness, but why does it matter ?
von
8 weitere Kommentare anzeigen
Antwort hinzufügen
dustytill wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 1,722
