reading fault code f20
my washer stop in the middle of its cycle and reads f20
Ist dies eine gute Frage?
Take a look at this link :
F20 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
I think it may help you...
If this answer was helpful please remember to mark it accepted.
War diese Antwort hilfreich?
I've been struggling with F20 on and off for a year... Cleaned the drain outlet, cleaned the inlet screens and fished a stray sock out from under the seal by the door. Finally noticed a green package of papers inside the bottom access panel on the side of the washer with a description if all the trouble codes and a wonderful diagnostic test.... Found out my washer was getting plenty of cold water and NO hot water at all on 4 of the 5 times I ran the diagnostic. Swapped out the water inlet valve (found step by step video instructions and how to test the old part for continuity on RepairClinic.com- they even had diagrams and schematics). So much better to be positive I fixed the real problem then guessing and randomly replacing parts!
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 18,091
