Why won't it turn on after screen replacement?
Hi,
I recently fixed the broken screen (cracked) on my ipod touch 4g. I went through all the steps on the guide here, and I when I had put the cables of the new digitizer into the ipod, I turned it on to see if it did before i closed it back up again. And I was pleasantly surprised, as it worked good as new!
I was putting it back together (putting all the screws in) and when i checked once more to make sure it worked before i applied the adhesive, it didn't power on :(. I thought it might have to do with the battery , so I plugged it in and it works, but its a white screen and half of it is pure white so you can't use that side. I've tried readjusting it, but could the cable still not be plugged in right on the digitizer? Also, the power button isnt working. Could this be part of the problem?
Thanks so much!
Ist dies eine gute Frage?
