Zum Hauptinhalt wechseln
Pavilion dv1000, Intel Pentium M 1.5GHz, 512MB RAM, 80GB hard drive
Media test failure, check cable
When you power up the laptop it doesn't boot. Message is media test failure, check cable. Exiting PXE ROM.
It also says For Realtek - PCI Fast Ethernet Controller
Any suggestions
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Kami VP, that error is typical of a failed hard drive. The BIOS attempts to boot from the hard disk which fails and then tries the next device in line which is often the network. Since booting from the network is possible only under very specific conditions, this too fails. Lacking another boot device it then issues the message and gives up the boot.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
hi im having that same problem, should I replace the hard drive or is it fixable thanks
von
@ocpelon01 that depends on what problem you have.
von
Antwort hinzufügen
Kami VP wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 21
Insgesamt: 2,884
