Part of my answer to this question, unfortunately, is "next time you buy a dishwasher, don't buy this one!" I have now repaired mine about 4 times -- cleaned out everything, including the grinder, the filter, the spray arm, etc. I even bought & installed a replacement grinder (for $11.... not bad; you can buy them at places like Home Depot, Amazon, etc.). To unclog any obstructions I couldn't see, I poured in boiling water, vinegar and baking soda, as well as dishwasher cleaner from the local hardware store before running the cleaned machine.
Everything worked - temporarily. The fact is that this machine is not very well made. The plastic parts are light (in part, I assume, because it takes less energy to move them), but they are not durable. Also, newer dishwashers that are 'eco-friendly' save on energy by using less-hot water. Unfortunately, most powder dish detergents do not dissolve as well in cooler water as in hot water, so you get lots of caked-on detergent (in addition to the food and other gunk) blocking points of entry and exit.
A wet-dry vacuum cleaner is a handy thing to have while repairing this machine.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
