Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
Frage geschlossen
iPhone 4s won't charge
Hi!
I have a iPhone 4s that took a swim. Everything seems to be working perfectly, except it wont charge.
I have replaced the dock-connector and the battery, but nothing has turned out working. The battery percentage keeps dropping as i write.
The charging symbol shows when the cable is plugged, but the phone doesn't charge. It is not recognized by itunes either.
However, if i plug the phone into a speaker-dock, music starts playing (from the dock). The microphone, loudspeaker and homebutton is working aswell, so i cant really figure out what the problem is. Is there any other parts i should try to replace?`or is there any other method i should try?
Any suggestions are welcome! i really need this to be fixed
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
You need to disassemble your phone and treat the logic board for water damage, here is a guide for treatment on a 3G but use these methods on your 4,iPhone Wasserschaden reparieren and here is a guide to teardown your 4, iPhone 4S Teardown, good luck, If this Answer is helpful please remember to return and mark it Accepted.
iPhone Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
iPhone 4S Bild
Anleitung
iPhone 4S Teardown
Schwierigkeitsgrad:
Mittel
War diese Antwort hilfreich?
Bewertung 1
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 4,714
