Zum Hauptinhalt wechseln
iPad Mini mit 7,9 Zoll Display und 16, 32 oder 64 GB Speicherkapazität.
630 Fragen Alle anzeigen
My ipad mini has troubleshooting
i updated my itunes recently, and now I had to restore my ipad mini. somehow it does not work. and it mention that they can't contact with the ipad software update server. My ipad screen consistently shows the usb charge and i tunes image. What should I do
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Put the iPad Mini in DFU mode connecting it to the iTunes to restore properly. Check if your firewall has been set to Block All Incoming Connections. iTunes will detect it and ask for restoring. Follow it. It will be done at ease.
To put in DFU mode, press Power & Home at the same time when the iPad is ON. When the screen goes completely black (after showing SLIDE TO TURN OFF), count down to 5 and release POWER button only and keep pressing HOME button for next 15 seconds.
If you liked this solution, rate it please. Thanks.
War diese Antwort hilfreich?
Bewertung 1
my ipad does not turn on
Bewertung 0
Antwort hinzufügen
ain wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 2,987
