Zum Hauptinhalt wechseln
Dritte iPad Generation mit Wi-Fi, Modellnummer A1416, erhältlich seit dem 16. März 2012. Die Reparatur erfordert Hitzezufuhr und vorsichtiges Hebeln.
154 Fragen Alle anzeigen
Part of the screen does not work
After replacing digitizer the top (assuming home button=bottom) part (about 0.85 inch) for left to right does not respond. What could be the reason? Looks like it is exactly 1/9 of the screen maybe that could be a clue?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Were you replacing the digitizer because it cracked, or because of a similar issue on the original digitzier? It could be a damaged connection that caused your initial problem.
Where are you buying the digitizer from? That could make a difference.
von
Einen Kommentar hinzufügen
2 Antworten
bad digitizer.. This is common, right out of the box.. 20 percent are bad, and on some, I have even had the connectors come out separate from the digitizer (yeah it was broken off).. don't doubt what your first inclination is, and don't make it any harder than it is..
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Tried another digitizer with the same result. still could be the digitzier (down to 4%). or maybe something else. do you know of a source that offers good pretested digitizers?
von
Ifixit and MobileDefenders offer great parts with excellent QA.
von
The left 10% wouldn't work for me first time. Went back and checked the ribbon connectors and managed to get it in another .1mm and also one of the plastic clips needed sliding in a bit after clipping it down. Perfect after that.
Bewertung 0
Antwort hinzufügen
boazparran wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 724
