Zum Hauptinhalt wechseln
Der PowerMac G5 ist ein Desktop-Computer, der erstmals 2003 von Apple Corporation produziert wurde. Diese Anleitung zeigt dir, wie du den PowerMac G5 (Modellnummer A1047, EMC: 2061, von 2004) reparieren kannst.
197 Fragen Alle anzeigen
Frage geschlossen
The temperature is about 90° and once it reaches 100°
sorry!
my friend give to me an old powermac g5 for big problem.
after mac os start, the temperature is about 90° and once it reaches 100° goes in protection.
i see no fluid loss, but i think the problem is with cooling.
any idea? thanks
this is solution? http://www.saunalahti.fi/~holindho/g5-qu...
really thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Is that 90 degrees F or C
von
is celsius degrees :(
probably i have to change water pump and get new liquid! it is not easy but I groped with the link step.
if I succeed, I will proceed with the calibration fan with ASD Dual Boot 2.5.8
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Run your Apple Hardware Test (AHT) from the original system installation disk. Hold down the "D" key on start up with the disk installed and see if its the coolant or possibly one or more of the fans.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
i will try, but all fans are going fast...
thanks for support
von
finally find asd but now the g5 won't start :(
his make fan check, and monitor don't show nothing :(
von
no moore idea?
really thanks
von
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 356
