Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2375 Fragen Alle anzeigen
What is error 3194 on iPhone 4?
I tried to reset an unlocked iPhone 4 to factory settings, and the phone froze and gave error 3194.
Ist dies eine gute Frage?
Bewertung 8
Einen Kommentar hinzufügen
13 Antworten
Hilfreichste Antwort
Finally I found a solution to fix error 3194 http://www.unlockboot.com/2015/01/fix-it...
War diese Antwort hilfreich?
Bewertung 2
Hey guys,
You can check out this blog post on how to resolve the 3194 issue.
http://dressmyphone.in/blog/solving-ipho...
PS: I wrote the guide and have tried to make it as explanatory as I can. If you have any suggestions then let me know.
Bewertung 1
It means that there is a problem with the current firmware of the phone. Here are a couple of ways to fix it http://howtofixstuff.blogspot.ca/2012/01...
Bewertung 1
me too was hit by the 3194 error on my iPhone 5 but the Hosts file solution didn't work, in my case it was the Comodo firewall on my computer that was causing the issue. I uninstalled it and the problem was solved ! I found the tutorial on hubpages to be effective most of other tutorial including the one from Apple forum were talking about this Hosts issue only without thinking that it is affected to jailbroken devices only.
Bewertung 1
If have a jailbroken device and trying to downgrade your device there chance for popping up 3194 error .This can resolved by using TinyUmberella
Download Tinyumberella
  1. Put your iOS device (iPhone , iPod or iPad) in DFU mode by :
  2. Switch off your device
  3. Hold the power button for 3 seconds
  4. Without releasing the power button hold the home button for 10 seconds
  5. After 10 seconds release the power button ( only power button ) and keeping pressing the home button for 15 seconds
  6. Now you iOS device is in DFU mode. Black screen will be displayed in you device display
  7. Connect to iTunes, device will detected in recovery mode in iTunes
  8. Now close the iTunes
  9. Open tinyUmberella and click on "start TSS Server"
  10. Now to open itunes and press shift (in keyboard) + Restore
  11. Point to the .ipsw file you have downloaded
(ipsw is the firmware you have download Eg: iPhone5,1_7.0.4_11B554a_Restore.ipsw .You can search you device firmware in google search )
Now itunes will restoring your device firmware
Done.
Bewertung 1
To resolve this error you can checkout a Guide to Fix 3194 iTunes error This guide contains the complete information with efficient solution related to this error. You can visit
Bewertung 1
Fix Error 3194 in iTunes Step By Step visit this web page : https://www.howtoisolve.com/how-to-fix-e...
Bewertung 1
mike, try this:"Error 3194 seems to be triggered when unsigned firmware is used, often during an iOS downgrade or even during some restores. Here’s how to resolve the error:
Fix Error 3194
The fix is the same regardless of what operating system you are using:
Quit iTunes
Locate your hosts file, in Mac OS X this is /etc/hosts and in Windows this is c:\windows\system32\drivers\etc\hosts
Open the hosts file with Administrator privileges
Add the following lines to the very bottom of the hosts file:
74.208.105.171 gs.apple.com
Connect your iPhone to the computer
Launch iTunes
Put the iPhone/iPad/iPod into DFU mode by turning the phone off and then holding down the sleep and power button for 10 seconds, then release the power button but hold onto the home button until iTunes tells you that the device is now in recover mode
Use the iTunes Restore feature as usual with the iOS device
Once your iOS update is finished, remove the “74.208.105.171 gs.apple.com” line from your hosts file again so that iTunes can properly update as usual." from here. Also, if you are using Windows, disabled the firewall. hope this helps, good luck.
Bewertung 0
1 Kommentar:
Also make sure you are using current iTunes.
von
Hello! you can go to this link to resolve problem. Hope this will help you out.
http://support.apple.com/kb/TS4451
Bewertung 0
Pretty much what OldTurkey said, but if you need more info, there's a long detailed article on this iPhone error at http://www.easynaija.com/iphone/how-to-f...
Bewertung 0
If failed again, you can download new firmware from others website and use i-tunes to load again. Remember try other firmware or download again.
Bewertung 0
error 3194 iphone 4g
Bewertung 0
what ever you need the answers you can find in the i tunes site only just go and visit iTunes site.
Sameera
Mobile covers and cases Designer
Bewertung 0
Antwort hinzufügen
mike wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 61,319
