Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
iPhone 5 home button not aligned after replacement?
Dear all, I have myself replaced the home button of my iPhone 5, the button itself and the ribbon cable.
Since then, sometimes the home button is slightly tilted to the left and sometimes to the right, which is a little bit annoying.
When I carefully disassembly the home button + the rubber gasket I noticed there was between the rubber gasket and the display assembly a very thin layer of adhesive.
Could be this adhesive the responsible for keeping the home button aligned or there is something I am missing?
If so, where could I get this adhesive?
Any help will be welcome.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
If Apple did the same thing they did with the 4 and the 4s then yes. Unfortunately that very thin layer of adhesive is responsible for holding the home button in place...
I'm not sure where you would be able to get the adhesive but when I did the repair on my 4s I just placed a cut strip of electrical tape over the back of the home button and it did the trick! Haven't had a problem since!
EDIT: Looking back at the teardown of the iPhone 5 it seems they introduced a support bracket that I assume was supposed to help with this problem (iPhone 5 Teardown)... I would check to make sure that bracket is fully tightened down, otherwise I guess you could try the tape method. Either way good luck!
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Yes, I also thought the metal bracket was to help with this problem. Unfortunately the bracket itself, without the unknown adhesive, is not enough.
Still I would love to know which kind of adhesive apples uses to glue parts that should be in place without glue. I bet this will be slightly modified in the next iPhone model.
If impossible to know, I will try you suggestion, of placing a cut strip of electrical tape over the back of the home button.
Thanks!!!
von
I have used a piece of two sided tape it worked fine. Hope this helps
Bewertung 1
Antwort hinzufügen
IgoKW wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,355
