No power & led light coming in toshiba satellite l300?
Hello sir,
I'm a laptop hardware technician. I have Toshiba satellite l300 there is no power and led light coming. I've tested the charger and battery its working fine and I tested the motherboard with multimeter shows around 20volts. Sir I would like to know what component is gone so that I could replace it with same model laptop?
Ist dies eine gute Frage?
Bewertung
0
Have you tried to remove the RAM, the Battery, and the AC adapter and hold the power button down for 30 sec. then replace the battery and see what you get. After that, try to remove the hard drive and see what you get.
von oldturkey03
I've tried to do the same what u said sir. And stiil it doesn't work.
von Anzar
What might be the problem and which component should be replaced?
von Anzar
Sorry led lights are also not coming
von Anzar
Can anybody help me to solve this problem?
von Anzar
1 weiteren Kommentar anzeigen
