Zum Hauptinhalt wechseln
Model No. A1367 / 8, 16, 32, or 64 GB capacity
914 Fragen Alle anzeigen
Removing old solder when replacing speaker
I broke the blue and red wires when replacing the screen, The red one broke off the board and the blue one didn't. The wires are still sticking out enough on the speaker to use them. My question is do I need to desolder the solder from the board it connects to? Someone mentioned in another post that you can solder these wires to the top of the board instead of the bottom where it previously was. There are two gold contacts on the top of the board directly on the opposite side of where it previously was soldered to. I know the solder is conductive but is it okay if i solder the wires on top of the old solder?
Thanks in advance!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Just tin the two wires and solder them back. If there is too much solder just use a braid and a bit of flux to remove it.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
How do you tin and why?
von
It should be ok but you shouldn't need to put more solder on the board, just heat the old solder up and stick the wires in wile its still melted.
Hope this helps,
John H. Laney
Bewertung 0
Antwort hinzufügen
Christa Bahr wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 364
