Zum Hauptinhalt wechseln
Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
21 Fragen Alle anzeigen
non-working torchier floor lamps
I have 2 nice floor lamps I think are repairable but I'm stumped. There is no maker info or parts list. I think it's the switches but have not found replacements that will fit in the stalk iof the lamp. Are they repairable or jut chuck them?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Post some images and lets see what you have there. They are lamps and I am sure we can find parts for it. Don't throw those out just yet :-)
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If you can't repair the switches, bypass them and add a foot toggle floor switch in the power cord. If you can't find that, then just put a rocker switch in the cord.
You might be able to replace the switch, but they are usually more robust than the socket. Check for a bent or broken connection in the socket and for damage to the cord. Check the cord tip for indications that it has a fuse in the plug. Good luck. Post images!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Rich Haddock wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 10
Insgesamt: 873
