Fills slowly on rinse?
takes twice as long to fill on rinse than on wash it is set to warm/warm
Ist dies eine gute Frage?
Paul,
Even though you have it set to warm for both wash and rinse, it could still be a water supply problem. You will want to check for a kinked hose, clogged inlet filter, or defective inlet valve. Before you could begin any repair, make sure to check first what temperature the water trickles out on the rinse cycle. Also test your machine by trying to fill it with both hot and then cold water on the wash cycle. Observe the flow and test the temperature with each setting to ensure that you do not have a supply problem with each individual temperature. Post your results here or let me know that you found the problem.
Daniel
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 139
