Zum Hauptinhalt wechseln
Der Game Boy kam am 21. April 1989 in Japan auf den Markt, dann am 31. Juli 1989 in Nordamerika und schließlich am 28. September 1990 in Europa. Er ist erkennbar an einem großen grauen Gehäuse und der Modellnummer DMG-01
68 Fragen Alle anzeigen
Power but no startup sequence
I recently dug out my old gameboy, but despite supplying power, I do not get the logo block or sound when turned on. the led is red, though that just proves the led works.
I've tried with and without a cartridge, and with an 6V AC Adaptor, as well as four AA batteries that are fully charged.
I've checked for leaked capacitors, or acid damage from leaking batteries, but it looks like i've been lucky and there is no visible damage.
I've measured the voltage on the contrast, and I get a range of about 0.05 to 10V on the pot.
I couldn't find a voltage differential on the audio pot however. should there be one there yet if a startup hasn't occurred?
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Steven Hodgson, could be a bit like looking for the proverbial needle in a haystack:-) I attached the power schematic for the GB and may be this will help you out. Check the caps on the DC-DC board. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
thanks for replying oldturkey03. using the schematic i've checked, and the power is coming out at roughly those values. i checked the oscillator this morning and still running 4.19 MHz too.
von
Antwort hinzufügen
Steven Hodgson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 344
