Air port and sound card not recognized.
After I changed thermal paste on MB pro A 1211, airport, sound card and usb, well basically left side of the laptop is not working. When I click on airport icon it says no hardware installed. I have checked my connections on logic board three times now and everything is connected. Help, anybody?
Thanks
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Punktzahl 0
Einen Kommentar hinzufügen
Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Antwort
Gewählte Lösung
It's not seeing the left I/O board: MacBook Pro 15" (Model A1211) Left I/O Board There are lots od connectors on this board and I've found that replacing these cures a lot of the suspected nVidia problem machines, Here's how to replace it: MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Replacement
MacBook Pro 15" (Model A1211) Left I/O Board Bild
Produkt
$34,99
War diese Antwort hilfreich?
Punktzahl 3
Kommentare:
Thanks for the fast response. What I would like to know why it`s not seeing left i\o board. Is this a voltage or bad connection related problem?
von
If it were in my shop, I'd go through reinstalling it, then replace it if it fails.
von
I was thinking about the same thing. Thanks. I`ll try to reinstall it, although I did not do anything with it during the thermal paste removal, but who knows. Thanks once again. I `ll let you know what happened.
von
The most difficult thing about this repair that I've experienced is the I/O board cable to the bottom of the logic board. It's easier to remove the cable from the I/O board and put it in the logic board first.
von
Exactly. That cable is a real sob to connect. BTW I solved the problem. It was the connector that connects logic board with the left io board. Connector seemed fine but after I could not power up the laptop I pressed it once again and sound card worked. After that I used the compressed air to blow out any dust that may be collected inside, reconnected it and every thing worked. I`m happy. Thank you for your help.
von
Antwort hinzufügen
Predrag Blagojevic wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 326
