Zum Hauptinhalt wechseln
iPod touch glass front panel raised a bit?
Can you help me to check if your iPod touch is like mine on this picture?:
as you can see in the photo, the glass cover is a bit raised over the chrome bezel at the bottom LEFT part.
is this common on most iPod touch? or it is manufacturing defect on mine? i never took it apart or dropped.
Many thanks in advance for your help.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
If the glass has ever been replaced, it's likely the adhesive and front bezel were not installed correctly or just are slightly off. If it really has never been opened or dropped, i wonder if it is some kind of defect-- perhaps it got warm and the adhesive slipped slightly causing the glass to become un-aligned.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Thanks for your answer. And there is a way to solve this other than opening it or taking to the Apple store?
von
No it's a different part with a different number
von
Mine is the same. There may be two models because I just ordered and received a new front panel from iFixit and got the wrong part. I requested a RMA on it but have not heard back from them. What is the model number on the back of yours?
Bewertung 1
8 Kommentare:
When i type the serial on apple it says iPod Touch (Late 2009)
The Model Number says: A1288
von
Mine is also the A1288
The part I needed was a FCAW 080728 GP4-3-C1.
What I got was a FC AW 091001 GP6-4-C2
von
Ben Eisenman, (iFixits great parts man), should be able to clarify this for us on Monday.
von
so probably my iPod touch was made with the wrong glass front panel? :(
von
Not at all. I think this model may have two different types of panels and ours has not been identified yet.
von
3 weitere Kommentare anzeigen
I to have this problem noticed a clicking while playing a game almost like the click the home button makes when dipressed it is not firm like the rest of the iPod touch as it can be depressed apple told me this is a result of dropping on the corner but as i informed them that is not the case i sent it in and was told there was No Problem this is a five month old 3rd gen iPod touch i know how it feels and this is a problem that will only get worse over time im afraid waiting for my iPod to get back from aple im not happy espically considering my first iPod Touch burnt up from the inside out while charging by the end of that service call it was to hot to even touch hope someone has a resolution to this
Bewertung 1
3 Kommentare:
Please start your own question. This has nothing to do with this question.
von
please just cut and paste this question to a new one and delete this entry.
von
Excuse me! Thanks for your your help! I am not sure if something was lost in the communication or what, but the exact thing has happened to my iPod, and I have sent mine to Apple and was just commenting on what happened in my situation. Usually that is what goes on in Q & A type forum, people share experiences to help each other. I didn't mean to upset you over something so mundane! Trust that you will not hear from me again!
von
I think the glue comes loose or dissolved with the heat of the hands... causing this. I'm going to use a hair dryer to dissolve the glue again then press the glass... hope this pops it back into its place
Bewertung 0
im also experiencing this!
what did you do to fix it?
Bewertung 0
Antwort hinzufügen
daikyouju wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 6,190
