Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
794 Fragen Alle anzeigen
Can I change the logic board to another one?
Hello
I have a MacBook Pro 13" from mid 2010 with a 2.4 GHz Intel Core 2 Duo CPU. I want to hear, if I can change the logic board in it, only the logic board, to a logic board from a MacBook Pro 13" from mid 2012 with a better CPU - this one: MacBook Pro (13 Zoll, Mitte 2012, Unibody) Logic Board Austausch
So that I'll keep my hard drive, batteri and so on?
Best regards, Mikkel
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Based on compatibility notes, the only direct drop in logic board is the faster 2.66GHz Core 2 Duo. This.
However, we love tinkerers, so see if you can make the newer one work. The ports should line up with the holes and the battery and hard drive have not changed since the MacBook Pro 13" was introduced. This is the Mid 2012 board that we have.
MacBook Pro 13" Unibody (Mid 2010) 2.66 GHz Logic Board Bild
Produkt
$249.99
MacBook Pro 13" Unibody (Mid 2012) 2.5 GHz Logic Board Bild
Produkt
$249.99
War diese Antwort hilfreich?
Bewertung 1
I have nearly the same issue like Mikkel. I have a faulty MacPro 13" from 2011. The boards (2011 and 2012) look exactly the same. Do you know if this configuration will work?
best regards
Bewertung 0
2 Kommentare:
The 2012 logic boards are not direct drop ins with your 2011 MacBook Pro. This is the logic board product listing for your 2011 MacBook Pro here.
von
The video connector is not compatible so based on that alone I think the answer is no. There may be other incompatibilities - isight camera, airport card. I love tinkering too but I wouldn't try that.
von
Antwort hinzufügen
Mikkel Kastrup wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,991
