Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2396 Fragen Alle anzeigen
How do I fix iPhone 4 'Error 2001'?
Hello, my iPhone 4 went into recovery mode after the Apple logo kept going on and off but would not boot up fully. I get the plug into iTunes logo and when I go into iTunes to restore it, it gives me 'Error 2001'. I just called Apple and they said it is a hardware issue. It is not under warranty anymore. What part could be causing this?
Ist dies eine gute Frage?
Bewertung 6
Einen Kommentar hinzufügen
8 Antworten
Hilfreichste Antwort
Based on the information found here, it sounds like replacing the battery wil solve the problem for you, and you can find those batteries right here.
iPhone 4 Battery Bild
Produkt
iPhone 4 Battery
$11.99
War diese Antwort hilfreich?
Bewertung 5
2 Kommentare:
replacing the battery worked for me! i had the exact same issue. Thanks!!!!
von
worked for me also! Cheers!!
von
Replacing the battery not work for me, any suggestion??
Bewertung 0
1 Kommentar:
Hi,
I am having the same problem! Did you ever find a solution?
Thanks
von
I have moved the whole logic board to a different chassi and I still get 2001 error
Bewertung 0
This problem is probably related to the battery. I had the same problem, when I unplug the phone, it stops working. I also had this error 2001 when trying to restore my 4s.
Bewertung 0
100% best solution!!
It is due to battery, but no need of replacement...
Yes, just ask in any mobile shop to put charge to your battery externally..
Now try inserting battery and restore will be successful!
Enjoyyy!!!
Bewertung 0
Is there anyway to charge the batter at homes without going to a shop? (I have the same problem)
Bewertung 0
1 Kommentar:
i'm sorry, with our cable it won't be charged. So please try to charge your battery in any other way. The only thing is to charge your battery... do not pay for any new battery.
von
You're the only person that has to do that
Bewertung 0
1 Kommentar:
The best way for my family to come out and get my hair is done
von
How to Connet network of sprint
Bewertung 0
Antwort hinzufügen
Josh K wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 16,280
