Zum Hauptinhalt wechseln
Zweite Generation des CDMA iPad mit 16, 32 oder 64 GB Speicherkapazität und Dual Core A5 Prozessor. Modell Nummer A1397. Reparatur verlangt Feingefühl, Hitzezufuhr und Hebeln.
52 Fragen Alle anzeigen
Backlight but no display on LCD
I have an ipad 2 that may or may not have been dropped by a child the issue that I am having is that there is nothing being displayed on the ipad, but the backlight is coming on and the ipad is recognized by i tunes i will be disassembling tomorrow any tips if anyone has experienced this problem before would be great.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
Hit the corner of the Ipad2 near the Headphone Jack, this trick worked for me and a few other people on the apple forum.
von
Einen Kommentar hinzufügen
3 Antworten
I would first check the LCD's connection to the logic board, and the cable's connection to the LCD. If the connections are good, then it's likely your LCD is bad. Be VERY careful when removing the digitizer. If it's not damaged, you don't want to break it when removing it to check the connection, or replace the LCD. Good luck!
War diese Antwort hilfreich?
Bewertung 0
There are 4 square like ic under the lcd connection
make sure you have all 4
Bewertung 0
Try hitting the top left-hand corner(headphone jack) a few times with your palm, it worked for me
Bewertung 0
Antwort hinzufügen
Alec wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,403
