How to fix white screen of death
how to fix white screen of death i have tried fixing by reseting restoreing(won't restore) please tell me how to fix WSOD without replaceing my lcd
Ist dies eine gute Frage?
Aufpolierte Version des iPhone 3GS mit schnelleren Verarbeitungsgeschwindigkeit. Die Reparatur geht ähnlich wie beim 3G vonstatten und braucht nur einfache Schraubendreher und Hebelwerkzeuge. Modell A1303 mit 16 oder 32 GB Kapazität mit schwarzer oder weißer Kunststoffrückseite.
In addition to force restarting and DFU mode restore, there are still other solutions for fixing iPad stuck on Apple logo:
Press and hold the Power and Home buttons till the screen is black, press and hold Volume Up and Power buttons until Apple logo reappears, and then release the Power button but keep holding the Volume Up button till you see the lock screen.
Restore or update the iPad in recovery mode. If you see any error codes iTunes, you can find the exact issue in the article: http://gg.gg/5824b
Use a third-party software to reinstall the iOS without restoring.
<Edited by Host>
watch video ... how to open iphone ... change screen and somehow disconnect battery from the main board.. one must work... but watch videos closely ... make notes and points ... do it stepwise ...
then place every thing back ... it is simple because the design of iphone is simple from inside
its even userfriendly for non users :)
i want my iphone fixed
If the iPhone White screen of death came randomly then you should try this fix [DFU mode].
1. Open Itunes and connect your iPhone to your PC/Mac
2. Press and hold the Home button and the Sleep/Wake button all at the same time.
3. After 10 seconds release the sleep/wake button.And continue holding the home button. Keep holding the home button until you see a message saying "iTunes has discovered an iPhone in recovery mode, you must restore this iPhone before it can be used with iTunes". There you have it your if is in DFU mode.
BUUM!!! it's done.
Kommentare:
Useless. If it's not a hardware problem, the best way to iPhone white screen problem is this way.
von KylieMinogue
Rep: 1
I have some sort of issue, mostly the same. Got this iPhone 3 for free. White screen, still sound. Did a iTunes recovery, then it won’t do anything. I took of the screen and reconnected the cables, is there anything else I can do that may fix the problem? I want to use it, but I need to fix it first.
Rep: 1
If you are getting white screen of death problem on iPhone or if your iPhone stuck on white screen with apple logo then you can follow this solution - How to Fix iPhone White Screen of Death
It will not only help you in fixing iPhone white screen with apple logo issue but also in problems like iPhone stuck in recovery mode, iPhone stuck on apple logo screen during boot, iPhone black screen issue, and many others.
Simply, follow the step by step instructions, and your iOS device will restart into normal mode.
Source: http://www.zerodollartips.com/iphone-whi...
I hope it helps.
Thanks
Letzten 24 Stunden: 1
Letzten 7 Tage: 8
Letzten 30 Tage: 27
Insgesamt: 20,357
my iphone 3g 16gb white screen..its LCD problem ? beacause its still sound when i turn it on..please help me :(
von Paolo
Don't worry,You can Fix iPhone White Screen of Death via DFU Mode.
Some Scenarios:
1. iPhone jailbreak failed.
2. Unsuccessfully updated iOS
3. Restoring iPhone from iTunes or iCloud.
If you don't know how to use DFU Mode, you can look at this article. It has a free way to help you.
von Jack hooo
If the iPhone White screen of death came randomly then you should try this fix [DFU mode]. http://gg.gg/581s5
BUUM!!! it's done.
<Link Edited by Host>
von Monionne
