Zum Hauptinhalt wechseln
2, 2.26, 2.53 oder 2,66 GHz Core 2 Duo-Prozessor
105 Fragen Alle anzeigen
Raptor HD replacement for Mac Mini Server?
Is it possible to replace the original hard drives in a mac Mini Server with a western Digital Raptor HD? Will the power supply spin it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The mac mini uses a 2.5'' harddrive. I don't know of any WD Raptor drives in the 2.5" form factor. The other concern here is heat and power usage. WD Raptor 10K drives are also major power hogs, so the machine will probably shut down from overdraw.
In short, it won't work. Get a SSD or a 7200RPM drive.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Agreed +
von
It is possible, but raptors are quite noisy and get hot, the latter makes them especially not good for mac minis. I would go with ssd or green, or blue models
Bewertung 0
1 Kommentar:
The Raptor is a 3.5" drive (has a special heat sink), sorry just won't fit as it was designed for 3.5" HD frame.
von
Antwort hinzufügen
Phillip Lauer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 5,851
