Zum Hauptinhalt wechseln
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
74 Fragen Alle anzeigen
Dead netbook except leds flash once when power supply plugged
Hi,
my laptop is a packard bell dot (same as the acer aspire one zg5) equipped with a hannstar j mv-4 94v, I disassembled it to fix a wireless module problem, then when i assembled it back and put on the battery the power and charge leds flash for a second and nothing happens when i try to power it on.
same reaction happens when i plug on the power supply or put on the battery.
even the battery doesn't seem to charge anymore (its indicator just flashes for a second as i said)
here's a video: http://youtu.be/ZpjB0Q9bVkU
any help or suggestion?
Thanks,
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
moeboe, if it worked before you did the repair, I would suggest that you double check your work. Make sure that all the cables and connectors are properly seated. Check the DC jack to make sure it is not loose on the board. Check your AC adapter and make sure it supplies the right voltage.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
thanks old turkey,
i'm actually trying to power on the motherboard only (without keyboard, screen...) and there's only one ribbon cable connector in it's place and there's still no working evidence.
any other suggestions?
von
Antwort hinzufügen
moeboe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,113
