Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Mitte 2006 / Modellnummer A1181 / schwarzes oder weißes Gehäuse / 1,83 oder 2,0 GHz Intel Core Duo Prozessor.
525 Fragen Alle anzeigen
open terminal at startup
I have a cd stuck in optical drive. I have just installed a new battery, which it needed. I need to get to the terminal to type in "drutil eject". Do I need to type it out as "drutil_eject" or simply type drutil(space)util"?
Any other suggestions? I have a macbook pro which I can hotwire up to the macbook (2007, 13-inch screen black body). Any fixes will be greatly appreciated. I am pretty certain that the optical drive is still good, but the DVD in it is just faulty. It will play when the operating system is up. I cannot get to the operating system, but will still try! Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hold down the space bar or mouse (track pad) at startup. That should eject the DVD unless it's warped or the opening is deformed.
Else you'll have to remove the drive and its top in order to remove the disk.
If this Answer is helpful please remember to return and mark it Accepted.
War diese Antwort hilfreich?
Bewertung 2
drutil is a command. It can take a number of arguments, but you're interested in just one, eject. The correct usage is with a space between them: drutil eject
What's the problem with the disk in the drive? If I recall correctly, you have to hold down a key (option?) to tell a Macbook to boot from a disk - otherwise it just boots as normal.
Bewertung 1
Antwort hinzufügen
Camille Nixon wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 198
