High HDD activity after Fresh Install
I recently picked up a used 15" MBP Core Duo for cheap. The hard drive in it was full and was just a small 160 GB..
As this was going to be a system that my kids were going to use and download tons of apps from the app store I decided that a fresh install of 10.6 would be a good idea. I also decided that having a larger HD would not be to bad of an idea either.
The owner of the MBP gave me a Retail DVD of 10.6 and I had a spare 500 GB lap top drive laying around so I puilled open the MBP and removed the old HD and droped in my new one. When I was in the unit i gave it a good cleaning to ensure the fans were clean.
I got the OS installed and everything seemed fine. Then i started to get the dreaded beach ball of death. It seemed that anytime I tried to access the internet via wifi the system would become unstable and the HD activity would go to 100%. I could move the pointer but was unable to click on anything. I decided to let the system sit for almost 30 mins and it still was unresponsive. I held the start button down and forced a reboot.. I turned off the wifi thinking it was the problem.. The system would again run fine but the moment I hooked the system up to the internet even wired the system become unstable and the only way to do anything is to hold the power button and do a forced reboot..
I can place the old HD in and go threw all the steps of a fresh install and all that jazz but I really do want to use the larger HD..
Any tips would help..
PS i have tried SMC & PRAM reset. I have done disk utility and it says the drive is ok and permissions have been repaired 4 times..
Update
Ok.. I am sorry for the long delay in my reply..
I do have the MBP 1,1 or Known as the A1150 Model..
I ended up having to order the original install discs so i could do the Apple hardware test..
Considering I confirmed the new HDD i was installing had the jumpers set to run at the systems speed of the 1.5 Gb/s
After doing all this I got a very odd Error when running the AHT.. I am unable to locate this exact error but from what I am reading this appears to be a logic board issue..
Error 4SNS/1/4000000: 'TCOP'
If anyone knows the exact meaning of this error I would greatly OFFERS700 knowing so I can attempt to repair this system for my kids..
Ist dies eine gute Frage?
4 Kommentare
Can you give us the last three digits of the serial number so we can correctly ID which model you have.
von Dan
How much memory does this system have and I would also check the specs on the HD you are trying to install and see what rev the SATA I/O is 3 or 6 Gb/s. Let us know what you find out.
von Dan
I have the Macbook Pro 1,1 its the 2.0Ghz Core Duo, I have 2 Gb of Ram.
The Hard drive is a Toshiba I am not sure if its SATA 3Gb/s or SATA 6Gb/s.. I cant read the full SN as they placed a stupid warranty sticker across the first portion. If i recall i was told it was the newer SATA 6Gb/s.
von Reatork
I believe you have an MacBook Pro A1150 model To double check get your serial number from Profiler or the About This Mac more info section then plug in the last three digits of your serial number in under the identify tab.
von Dan
