I can't charge my iPod
Hello,
I can't charge my ipod anymore, but I used 3 different chargers so it's a problem with the ipod, what can I do?
Ist dies eine gute Frage?
Hello,
matthias, check your dock connector for any bend or broken/corroded pins. Clean it with some isopropyl alcohol and a few puffs of compressed air. If that does not make a difference, you might start by replacing the battery. Here is the guide for it and the battery is available right here as well as many other places. If a new battery wont work, you may have issues with either the dock connector or the PMIC as well as the charging coil itself. Those are not easy fixes....Hope this helps, good luck.
War diese Antwort hilfreich?
I have this same problem. Please help.The iPod wont function with the charger but it works fine otherwise.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,168
2 Kommentare
Is it being recognized by iTunes (or your computer) when you plug it in?
von oldturkey03
i have the same problem. my ipod wont charge but I know it is not the ipod's battery . it is the bottom part that I plug it in . how could I fix that?
von jhony
