Zum Hauptinhalt wechseln
A 4GB 3.6" Touch Video MP3 Player by Sylvania.
2 Fragen Alle anzeigen
Why won't player turn on?
I have tried over and over again to turn my player on. I have tried charging it several times and have even tried the reset button, but it will not come on. It was working fine, then I started downloading some more music when it shut off and would not turn back on. My laptop recognizes that it is pluged up. I only have a USB cable to charge it and I have even tried three different USB ports on my laptop. What is the cause and fix for this problem?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
henryr79, it does sound like a battery failure. If it has discharged to below its threshold it will no longer accept a charge or hold a charge. I would start with that. Follow this teardown to change your battery and re-evaluate. hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
What does a battery cost and where can one be bought?
von
Once you have it apart, there should be a number on the battery. Use that to do a search according to your location.
von
It was not working and how to fix it.
Bewertung 0
1 Kommentar:
Um... what are you talking about???
von
My sony walkman wont turn on
Bewertung 0
Antwort hinzufügen
henryr79 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 2,453
