Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2010 / 3,06 & 3,2 GHz Core i3 oder 3,6 GHz Core i5 Prozessor
Upgrading CPU from i3 3.06 Ghz to i5/i7-S version 82W
Hi,
I want to give my iMac i3 an upgrade to i5 or i7 processor.
I've red some posts of some people who tried several combinations.
Some combinations worked, some didn't.
The CPU's that didn't work were the CPU's with a TDP of 95W.
The i5 CPU's that have been tried out and worked were the CPU's with a TDP of 73W. My big question is; There are several CPU's with a TDP of 82W like the i5 750S/i7 860S/i7 870S.
Will those CPU's work? I can't find any information on the web with these specific CPU's....
The TDP is ±9W higher then the standard i3..
Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
2 Kommentare
Hi again everyone! Just thought someone might like to know that the Xeon E3-12xx v1 CPU’s work in 2011 iMacs ! I have a E3-1260L in my current 2011 21.5”. Only 45w
4cores 8threads 2.4-3.3ghz 8mb L3
von
von
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Apple has used so many different CPU's in their systems I doubt anyone has a listing what works in which logic board. A better way to do this is to get down to your CPU in your system and make note of the part numbers, then go to Intel's web site and look it up. Once you know the CPU series you can select a different chip within it.
War diese Antwort hilfreich?
Bewertung 4
10 Kommentare:
I don't think you understand me right.
The thing i'm doubting about is the power consumption of the cpu.
The power supply in the iMac 21.5 inch is 205W.
I've red some experiences of people that tried some 95W cpu's that failed to boot, because of the higher TDP.
The 73W cpu's actually did work. (for exampe, upgrading to an i5 680)
The big question is: Will the 82W cpu's work?
I need to know it from someone who has experience with that specific replacement
There is no CPU restriction on certain models or something.
It's just the power-consumption issue
von
No, I understood your focus is the chips TDP value. You still need to work it out the way I explained here. Locate your exact systems CPU in Intels' lists it will tell you the TDP of what you have now and within this series the other chips that can be used that meet the TDP value window (+/-) the system was designed to support.
von
The problem is that I don't know if the iMac is limited to 73W CPU's.
Maybe it can take more than 73W but less then 95W
I already saw a list of cpu's that have the same TDP but I want to know that if I exceed the 73W, the machine will work with the new cpu.
waiting for someone with this experience.
Thanks for you answer though
von
Snappaz, I think you are mixing things up a bit. TDP is not the same as power usage. It is the measure of heat dissipation in terms of wattage. "maximum amount of power the cooling system in a computer is required to dissipate"
von
Old Turkey,
Thanks for your answer.
I know, but more heat dissipation of the cpu means in the most cases more power consumption... (If i look on some benchmarks, the 95W TDP cpu's also consume almost 20W more power than the 73W Cpu's.
If i look on this http://cpuboss.com/cpus/Intel-Core-i7-86... website and the differences I see that the i7 consumes less power, I will take the gamble and place an i7 cpu.
von
5 weitere Kommentare anzeigen
Hilfreichste Antwort
The i7 870 has TDP of 95W but thats irrelevant the power consumption is of 121W and the 21.5 imac doesn't have the juice for that.
But ! the i7 870S (wich is the low-power variant) has the TDP of 82W and squeezes 66.63W from the power source. Bingo ! We have a winner.
I can confirm it works, i have the 21.5 mid-2010 imac with the i3 550 (dual core) now housing the quad i7 870S (2.66GHz turbo boost up to 3.6GHz, 8MB L3 cache). 4K video was a no go with i3 now plays smooth on i7, everything is blazing fast and I haven't even upgraded to SSD yet. the only thing I did notice is that in System Report I had 5.86GT/s Processor Interconnect Speed now its 4.8GT/s.
Did a lap on cpu before mounting in socket, reports 41 degrees Celsius on all cores never went past 60 in full load. The i3 had 44-46 on average use and difference of 1-1.5 degrees between cores.
Bewertung 12
10 Kommentare:
Good answer! Thanks for taking the time to document it here.
von
Hi David I'm Gerard, any idea where I could find one of those cpu's for sale ? I'm not having much luck in tracking one down... Thanks for the great piece of information.
von
Gerard - Sadly, you maybe fighting an uphill battle to find the CPU ;-[
Intel had long since stopped making them. You'll need to get the Intel part number from the link I posted above, then see what you can find on the internet. You might also want to try some of the Apple dedicated parts houses.
von
Hi @zeerocool
Thanks a LOT for your answer. It gave me hope that I can upgrade my beat-up iMac to an i7 model.
Sadly, the 870S you used is now discontinued and I cannot buy it.
I will be really grateful if you can recommend another current model that would fit my machine?
I have the low-end 21.5" iMac mid-2010 with an i3-540 (3.06 GHZ) processor.
Thanks in advance.
von
@khalrez - I've tried get one for someone else who wanted one I was unable to find the needed CPU and I sourced far & wide. Sadly, thats the only i7 chip that will work in this system.
Sorry no substitutes possible. Intel has changed things so nothing else is possible.
von
You can use the L3426 Xeon in the 2010 iMac !It has a lower power consumption 45w and gives 50% increase in multi core performance.
Shows as i3 1.86ghz in system profiler but can boost 1 core to 3.2ghz or 2 cores to 3.06ghz when needed.
Bewertung 3
4 Kommentare:
Can you post a geekbench score? I was able to get a 870s(its not arrived yet), would be interesting to compare the two.
von
I think I might have a 3470 around, if I do I'll try it and see what happens.
von
That won’t work it’s a 95w chip.
Use the L3426 (low power Xeon) 4c/8t 1.86-3.2ghz.
von
Update for anyone still playing with these old imacs...
You can also use Xeon E3-12xx (v1 only) in the 2011 imacs, up to 3.5ghz 4C/8T , best to go with the chips without the onboard graphics otherwise pciex16 will get split to pciex8 between the CPU GPU and your dedicated GPU. I have used a E3-1260L and a flashed nVidia K2100m together, ran Monterey while it was the current OS no problems using oclp (2011 21.5")
von
I have a mid 2010 iMac with a core i3 3.06 GHz CPU, and ATI Radion HD card with 256 MB a video room, and the 500 GB 7200 RPM HD. I am about to do an upgrade of the CPU, the GPU, and the Hd to SSD. It’s going to be a long tedious job, but doable. They are basically only two processor upgrade options that I am aware of and I chose to go with the Intel quad core i7 2.93 GHz That has the same socket type as the stock CPU. There is another core I five option, but I am upgrading this to the max. If you upgrade to the iOS 7, then you can use 32 GB of RAM instead of the 16 GB limit. Also, there are other graphics card options pulled from other imacs purchasable and eBay that you can swap for the stock built-in one. Changing from an HDD to an SSD is an enormous improvement in performance. And I’m not just talking about disc performance. But the entire system. I didn’t believe it until I tried it. As far as I know from everything I have read, there is no need to change the power supply when going with the CPU that I have bought. I’m actually about to commence the upgrade right now and really not looking forward to it. There are a ton of screws to remove in a lot of parts to take out. You literally have to disassemble the entire thing. As long as you follow the instructions and are very careful, it will be well worth it. You can take an 11 year old iMac and for $200, turn it into practically a brand new one as far as performance goes. The benefit is, you have peripheral ports that no longer exist so that hardware you might have that is fully functional you can still use, and you will not be forced to upgrade software because you can also run older versions of Mac OS X on other partitions. It’s also possible to remove the internal SuperDrive and replace it with another SATA SSD if you so choose. If you have the time, the patience, and the confidence, I say go for it
Bewertung 0
2 Kommentare:
any updates on your urpgarde? did the new cpu work?
thank you
von
I procrastinated. Believe it or not, I am just about finished. CPU and GPU upgrade went smoothly. I already had 32 gigs of ram working with the i3. Putting in the SSDs now. Don’t for see any problems. Went with the core i7 860s
von
Yes, i5-750S, i7-860S, and i7-870S (82W TDP) should work in your iMac if it's LGA1156-based and properly cooled, but avoid 95W CPUs.
Bewertung 0
Antwort hinzufügen
Snappaz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 50
Insgesamt: 8,424
