Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
Why won't the flash Work after the screen replacement
I just replaced the screen for the iPhone 4s and put it back together. Everything worked great, but the Camera flash. The camera worked also. I was wondering if this is fixable or if I forgot to put something back in while putting it back together.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
heyy anyone can help me with j7 samsung . I had just replaced the screen for samsung j7 2016, Everything is working except the front flash camera .I dont knw wat to do
von
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
There is a gold grounding clip that goes behind the top of the camera. When you disassembled the phone, you had to peel off that black tape and remove a screw that holds it in. Make sure that you put it back in.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I forgot to put that back in, but I lost it and already ordered a new camera. Will the little piece come with it?
von
I meant will the new camera come with the little piece?
von
Hilfreichste Antwort
Hi everybody. To day I had thesame problem. What was wrong? There is a gold plate whos touching the camera from back side. This must be monted just under the screau, I put under the motherboard and was NOT working. I change place like i say + there are 2 plates on the right and left side of the connection tape of the camera. They must touch mainbord alsow. My camera is back OK. Hope i help.
Bewertung 2
Do a hard reset if that doesn't work make sure the camera is seeded correctly.. If that doesn't help u needa replace camera and flash
Bewertung 1
try to resample the camera socket and look for ant damage it happen with pins
Bewertung 0
My iphone suffered water damage - %#*@ the beer!
So I stripped it down and cleaned the motherboard with Methylated Spirits (de-natured alcohol) paying particular attention to the area where the camera and flash attached and the sim card contacts because both the flash was permanently switched on and the sim card wasn't recognized anymore. This fixed the phone! Or so I thought!
I noticed that the front camera wasn't working so I tried opening the phone to check the front camera plug had properly seated on the boards corresponding socket. This didn't fix the front camera.
HOWEVER I found [several days later] the rear camera grounding clip loose on the floor of my bedroom and thought "that'll fix it hooray". It turns out that when I re-fitted the rear camera grounding clip and re-assembled the phone; the flash wouldn't turn on leading me to believe that having already used the rear camera and attempting to switch to the front camera (which requires a lower voltage jumper to start it ) - that I had subsequently broken the jumper for the front camera because the rear camera wasn't grounded when I first tried to switch from the rear camera to the front camera. SO I removed the rear camera grounding clip and what do you know - the flash works again! I hope this helps
Bewertung 0
Hello guys , i had given my mobile samsung J7 2016 to repair recently . The repairer just replaced the screen. After getting my mobile , everything worked great except the front Camera flash. Now i went to see him again as i did not check my front camera there. He told me that the front camera flash is not connected to screen and i need to buy camera sensor to change it . Is that true that the front camera flash is not connected to screen ! I just dont knw wat to do? CAN U guys help me
Bewertung 0
Antwort hinzufügen
Luke Turner wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 5,416
