JMH, after the copy job is finished, press to reset the settings to the default. The resize setting also switches to 100% after two minutes of printer inactivity. If that does not work, try to reset the power:
1 Unplug the power cord from the wall outlet, and then wait 10 seconds.
2 Insert the power cord into the wall outlet, and then turn on the printer.
If that does not work, you may have to try to reset it:"Resetting to factory settings
Resetting to factory default settings will delete all the printer settings you have previously selected.
Using the printer control panel menus
1 From the printer control panel, press .
2 Press the up or down arrow button to scroll to Defaults, and then press .
3 Press the up or down arrow button to scroll to Set Defaults, and then press .
4 Press the up or down arrow button to scroll to Use Factory, and then press .
5 When prompted to set the initial settings of your printer, make your selections using the printer control panel buttons.
Initial Setup Complete appears on the display.
Using a button combination (if you cannot read the current language)
1 Turn off the printer.
Note: If you have set the Power Saver timeout in the Setup menu, then press and hold for three seconds to turn off the printer.
2 From the printer control panel, press and hold and , and then press and release to turn the printer on.
Note: Do not release and until Language Selection appears on the display, indicating that the printer has been reset.
3 When prompted to set the initial settings of your printer, make your selections using the printer control panel buttons.
Initial Setup Complete appears on the display." You can also get the manual from here. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
