Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2396 Fragen Alle anzeigen
"this device has malfunctioned, windows doesn't ..." what do I do?
i have followed all of apples support tips, restarted apple mobile services, removed all of Itunes components for a clean re-install. i tried resetting my iphone to factory default now its stuck in limbo cause of the same error message "This device has malfunctioned and windows does not recognize it" what do i do to fix it please???? i have just about given up and cant think of anyway to fix it and now all i have is a $200 paperweight!!!!!!!!!
note: it doesn't even show up in Itunes either and i'm running Itunes 11.3.1
and under device manager its "unknown device" cant update drivers, nothing! Does anyone know what would be wrong hardware-wise????
Ist dies eine gute Frage?
Bewertung 0
7 Kommentare
Have you tried a different computer? Which version Windows do you have? This could be an OS error.
von
i have tried using my brothers laptop as well, he's running windows 7, my laptop is running windows xp 32-bit, all different sync cables including oem apple cables. both laptops have usb 2.0 ports and under device manager the "unknown device" property->details-> say 0000something00 which i read some where that its a hardware failure that's why i was wondering if the new charging port i ordered would fix the problem or was there anything simpler i was overlooking
von
It is a good idea to start with the dock connector. After all, that is your phones connector to the world:-) Let us know how it is going.
von
replaced the dock connector but alas no solution as of yet :,(
von
I'm going through the same thing and I'm freaking out.... There's gotta be some one out there that can help....
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
leave it powered off for 5 days this is like disconnecting the battery thus it will reset itself and reboot when powered on..also try other usb connections and charging cables I have this thing happen all the time..have you downloaded sumthing that has interferred with usb docks..try an early system restore see if that helps..
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
i left it off for a week and replaced the dock connector and i am getting the same error mssg, as far as downloaded something no cause my ipod touch works fine, i'll try the system restore as a last resort cause i have no idea when my computer was backed up last.
von
does anyone have any suggestions as to what may have shorted out on the logic board that would cause this error? and is it even repairable?? :/
von
mine has done the same thing also
Bewertung 0
Antwort hinzufügen
death byinjection wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 14,486
