Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Modell von 2011, A1278 / 2,3 GHz i5 oder 2,7 GHz i7 Prozessor
807 Fragen Alle anzeigen
Keyboard replaced but power button not working!
Hey guys, a few months ago I spilt liquid on my beloved macbook, I took it apart and cleaned it and it worked again although the keyboard wasn't working properly. I plugged in a usb keyboard and it worked fine.
Here's the problem...The power button was working fine and would boot up my mac whenever pressed. I've just got around to replacing the keyboard and it that works, however now my power button now isn't working!! I have to remove the bottom cover, disconnect the battery and reconnect it again for it to boot up.
Any ideas on where to go from here to resolve the issue would be greatly appreciated - Thank you!
Matt
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
Nintendo Switch Kits
Eine schnelle Lösung, um wieder ins Spiel zu kommen
Switch Kits kaufen
Switch Kits kaufen
2 Antworten
Matt,
Since the power button is connected to the keyboard, you may have not installed it correctly. It sounds like you may be shorting out the button, or its getting pressed down, but then not coming back to the up position. I would look at take the MBP apart and making sure the button is positioned and installed correctly.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
Thanks for your reply flogo. I have checked whether the button is installed properly and it seems to be, also I can feel and hear the button 'popping' back into position so I presume that isn't the issue. When I opened my mac back up and unscrewed the button again I noticed a small silver washer placed between the button attached to the keyboard and the button on the main unibody, I removed it and tried again but no joy so I put it back, would this have anything to do with it do you think? Also how can I tell if I am shorting out the button?
The button on the new keyboard could be faulty I guess! Thanks again for your help its much appreciated.
von
I have problem of macbook pro A1286 model 2008
Problem is
power button is not working
Power on with f5 key
Back lit also working
Everything fine with external keyboard
Keyboard does not work. Some key of top row works. but other does not work properly. shall I need to replace or resetting problem ?
Bewertung 0
Antwort hinzufügen
Matt Heath wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 1,874
