Zum Hauptinhalt wechseln
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60 Fragen Alle anzeigen
Overvoltage at 12V and Died Razr
Heedlessly I connected a car charger wrong and my razr took a power surge at 12v. Now the phone will not turn on and will not charge, it seems dead. What can I do to solve this problem?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
2 Kommentare
You will have to open it up and check for some obvious damage. Look for some burned, charred or missing components first.
von
I have just opened it, I compared it with another razr XT910 and seems thar are identical.
I exchanged the motherboard and I have found that it is the cause of damage.
Unfortunately, the chip on the motherboard are covered with metal parts, but I don't know how to remove for exploring the damage circuit.
Meanwhile, thank you so much for the help you're giving me.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I would check for an onboard fuse. use a magnifying glass and look around the charger area for a F1, F0, etc.. Can you post clear pics of the mainboard? Both Sides
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Maurizio Luciani wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 301
